PC4 Arp multi question
A month into PC4 ownership and I'm loving it. Not really a newbie to programming but never experienced Kurzweil before and it's so far quite intuitive to my past keyboard experiences.....but....maybe this is a firmware problem, I just can't get my head round this..
Nothing coming up in search and scratching my head.
I need a Multi patch with a single (zone 2) arp triggered bass line, which I have managed to make. When I save the patch it saves with the arp on the other layers in the ON state no matter how I try to make sure only the zone I want arp in is on. The manual says this should be possible, I can play the patch successfully after I save it but the second I exit to select a different patch the arp is in the ON state in zone 1 where I specifically don't need an arp....what am I missing?
Thanks in advance.
