pcr 800 chanel change using 16 velocity pads
pcr 800 is really very great interface...
i have made some workaround for midi chanel change
may be helpful to you
the rar file contains the instructions
please check my foram link http://www.vstclub.com/forum/59-40744-1#587290
this is new bidule file
http://rapidshare.com/files/385906300/chanel_change_final1.rar
I am very interested to see your midi channel workaround using the velocity pads. I've been searching for a solution to this problem for quite some time. would you be able to re-post the rar file?
Hi, I realize this is old but I would like to know about the midi channel change solution for the PCR-800. The rapidshare link is dead. Is there anywhere else I can view this? Thanks
