Thanks Dave. I’ll post some pictures this evening.It would help to understand what type of connector is needed.
Audio Controls: | Front panel volume, treble, and bass sliders. |
Audio Outs: | (2) line level RCA jacks |
Audio Ins: | (2) line level RCA jacks (for connecting external sound sources) |
Headphones: | (2) 1/4″ stereo headphone outs |
MIDI I/O: | MIDI In, Out and Thru jacks. |
OS Updates: | Flash ROM allows for updating of the Operating System via disk. Operating Systems can be downloaded at no charge. |
Pedals: | (3) programmable switch-type: sustain, sostenuto, soft (defaults) (1) programmable Continuous Controller (volume by default) |
Pitch Bend: | (1) Ribbon strip |
Finishes: | Ebony, Mahogany Red, and Mahogany Brown Polish |
Bench: | Matching bench included. |
Dimensions: | 39.75″(H) x 58.25″(W) x 59″(D) |
Weight: | 512 lbs |
Hi Dave,I pulled the description from the Kurzweil site. Here is what I see:
Audio Controls: Front panel volume, treble, and bass sliders. Audio Outs: (2) line level RCA jacks Audio Ins: (2) line level RCA jacks (for connecting external sound sources) Headphones: (2) 1/4″ stereo headphone outs MIDI I/O: MIDI In, Out and Thru jacks. OS Updates: Flash ROM allows for updating of the Operating System via disk. Operating Systems can be downloaded at no charge. Pedals: (3) programmable switch-type: sustain, sostenuto, soft (defaults)
(1) programmable Continuous Controller (volume by default)Pitch Bend: (1) Ribbon strip Finishes: Ebony, Mahogany Red, and Mahogany Brown Polish Bench: Matching bench included. Dimensions: 39.75″(H) x 58.25″(W) x 59″(D) Weight: 512 lbs
Are you missing the cable that connects the pedals to your 152? Please provide a little more clarity as to why you would need the cables and not the entire pedal units themselves (which typically have the cables already connected to them). Also, in the above picture, which cable for which pedal are you in need of?
I'm asking these questions because as I look at a picture of a 152i (https://www.ebay.com/c/1963660567) it appears that the 152 already has pedals attached to it; so I'm trying to correlate your question about the cable to the pictures. The only thing I can think of is that the cable connecting the pedals to the keyboard is broken or missing and you're trying to replace it.
Hi Dave,
What happened is a puppy chewed through the cable some time ago and I have misplaced the end that looks like a midi connector. I disassembled the pedals to get the other end of the cable. I have included pictures in emails to you.
