- Joined
- Jan 25, 2020
- Messages
- 2
- Reaction score
- 0
Hi all! I bought a brand new Yamaha MODX 7 and after about 2 months the keyboard goes out of tune at times. Has anyone else faced the same problem?
The problem is probably the pitch bend wheel or joystick whichever it has.
Check your manual to see if there is a calibration procedure.
Otherwise if it's still under warranty bring it in for service.
In the meantime as a workaround you can always disable the pitchbend.
Again consult your manual.
