PK-5A w/ JV-1080
Just purchased a set of PK-5A pedals and a 1080 module. I'm trying to figure out how to let the notes ring out just a little after I lift my foot, so that there won't be any dead air between notes and still be able to end the song with the rest of the band. Thanks
Perth, Scotland
You need to edit the sound in the JV1080 (if that's possible).
Never owned a JV1080 - can you edit the ADSR envelope of the sounds? If so increase the R (you may need to put up the values of both the S and R) until it hangs on a bit after you release the pedal.
(ADSR = Attack Decay Sustain Release - you use it to shape the sound)
Thanks, I will try it later and let you know. The Manual is like reading a Physics book!
