- Joined
- Dec 26, 2007
- Messages
- 3
- Reaction score
- 0
Hi,
I am playing a GEM PRP 700 through a Fender Hotrod deluxe. The lower key sounds are much louder than the higher key sounds. The imbalance is so great that I am scared to play left hand and right hand together. Changing the settings on the amp hasn't helped. Changing the settings on the keyboard doesn't really help either.
Is there a pedal I can buy which can effectively dampen the lower note sounds so that the keyboard produces an even sound?
Thanks
Simon
Thanks
Simon
