First, I don't think the VI25 editor is designed to remember which MIDI In and MIDI Out ports you had selected during a prior session, but I might be wrong about that-- I mean, one would hope that the program could actually detect that the VI25 is attached and select it automatically by default, since its whole reason for existence is to let you create and save presets for the VI25.
Second, after you have saved the desired settings to a preset, you need to actually select that preset on the VI25 or it won't take effect, it will just be in memory as one of the available presets. Well, I guess if you save the settings to preset 1 then the VI25 may load preset 1 by default, but the whole point of being able to create a dozen or more presets is so you can select whichever one you want to use.
Loading the preset back into the editor doesn't activate the preset on the VI25, it just pulls it back up in the editor so you can look at it, change it, and save it again if you want.
What you need to do (after saving the desired velocity curve to preset 2) is use the "Preset Down/Up" buttons on the VI25 to scroll to whichever preset you want to use. I don't have a VI25, but I'm guessing that it powers up with preset 1 selected and that pressing "Preset Up" once will make the preset number go up from 1 to 2. Then the VI25 should use the velocity curve setting that you saved to preset 2.
EDIT: Just to help clarify things, you don't need the editor for anything except to create and save presets (and it might even be possible to create and save presets on the VI25 itself without using the editor, but I don't know about that). Once the presets have been saved to the VI25, you don't even need the editor anymore-- you can use the VI25 with your other MIDI hardware or software without needing to have the editor up and running.
