Pocket MIDI problem
Arizona
I am trying to set up a connection from a PC to a Yamaha Clavinova using a USB-to-MIDI adapter cable. The hardware connects and works just fine.
I'm using MuseScore 4 on the PC and want to use a MIDI monitoring program (Pocket MIDI). However MuseScore and Pocket MIDI will not connect simultaneously. It's one or the other, but not both.
What an I missing here???
Texas USA
Can you set the first one to "MIDI Thru"?
Also, I'm not sure which model Clavinova you have. But the Tyros, Genos, and PSR pro arrangers have two sets of MIDI ports (USB and 5-pin DIN MIDI). If your Clavinova also has two sets, perhaps you could make use of both of them to solve your problem?
LoveLoud
