- Joined
- Jul 17, 2017
- Messages
- 5
- Reaction score
- 0
Greetings. I have a Privia PX-350. One Bb key sounds the note when you strike it, and then it sounds again when you release the key, so you get a double-hit effect. If you strike it softly, it doesn't do it, have to hit it a little on the hard side. Also, I discovered that using an organ patch, normal function would be for the organ note to keep sounding as long as I hold it, but on this key, the organ sounds for a second and then stops. Then when I release the key, it makes another quick sounding of the note.
I have some technical ability, not afraid to open it up and poke around, but before doing that, thought I'd see if anyone knows if this might be a simple fix, or needs to be taken into to someone with more knowledge about it than I.
Thanks!
Thanks!
