- Joined
- Aug 8, 2012
- Messages
- 4
- Reaction score
- 0
hey everybody... I'm new here and trying to help a friend...
he needs to change stage settings quickly without doing 20 button pushes... his main keyboard is a Yamaha Motif 8, and secondary keyboard is a Korg Triton LE... he is not a MIDI guy and has been doing his settings manually... he has access to a Windows laptop (probably WinXP) and an older version iPad... I'm assuming that using Control #s 000 and 032, then the program change would get the job done for each keyboard... would he need to use a sequence program to do that with the laptop and additionally, is there an app for the iPad that would do the job...?
I'm an old guy... when I had this issue years ago, I used a Yamaha MEP4 to set keyboards and external FX units... I'm guessing that it would work for this if I can find one... of course, he'd like to spend as little expense as possible...
I scanned over the Motif 8's manual and saw no way to send bank and program changes as presets were chosen on the keyboard...
I'm sure several of you have dealt with this issue before and I'm thinking that y`all might have newer and better ways than what I have outlined here... any help is appreciated...
