Psr-E423 HELP
Sweden
Hi prasannaf,
what do you mean with 'program a song'? If you mean to change tones (for example instead of piano a string voice) yes you can do that. You can also record until five of your own songs and store them as user songs. But if you want to program seriously you need a sequenzer software and a computer connection via USB which is possible. Anyway read the manual you can download free.
http://www.google.com/url?sa=t&sour...sg=AFQjCNHGIEmR4LN8ueDnF1ierT_48ybWFA&cad=rja
With regards
goldi5210
Hi prasannaf,
With regards
goldi5210
can i play a midi file transfer in to this keyboard from computer ???
j levasseur
