Question regarding akai mpk mini
hi guys
i have just bought akai mpk mini and my main choice of DAW is ableton
right before acquiring akai mpk mini , i was pretty reliant on MacBook keyboards
now that i can use akai, it def facilitates the whole process
but me being a noob, i have a question :
if i assign for example an arpeggiator and an octave `down` to one midi file, but don't wanna use the same for another midi, though still wanna use akai for lets say another synth or drum machine (it is still automatically set to my first midi with the aforementioned arppegiator and an octave)
do i have to manually adjust each time? or freeze and flatten the track ?
any info would be helpful
Are you using the MPK Mini's arpeggiator and octave-shifting features, or are you doing it within Ableton Live?
Also, are you trying to control multiple instruments at the same time with the MPK Mini, or just one at a time?
I’m using the MPK Mini's arpeggiator and octave-shifting features within Ableton Live and I’m trying to control multiple plugins at the same time on several midis
How possible is it to assign features on one midi and then to start on a clean slate with another midi (with a different Plug-in) ?
Or do I have to drop arpeggio from effects panels thru ableton manually for other midi?
Rajitha
