[SOLVED]Radio Shack MD-1700 (clone of Casio WK-1630) to PC via Yamaha UX-16 USB cable
Hi! I own a RadioShack MD-1700 keyboard (a clone of the Casio WK-1630 brand, so info on that keyboard might be relevant) in good working order, which I'm trying to connect to Finale 2012 on my Windows Vista PC with a Yamaha UX-16 USB cable. I've plugged the cable's MIDI-OUT plug into the keyboard's MIDI-IN jack and vice-versa. The drivers for the cable have been successfully installed and Finale detects the cable. The keyboard turns on and produces sound.
On the keyboard, MIDI is set to output on channel 1, and this is the channel where the sound goes when I play the keyboard normally (according to the "Musical Information System" on the keyboard's LCD screen).
I just realized that the cable actually is getting MIDI data from the keyboard (an indicator light flashes when you press a key, as I only just saw), so the problem is actually that either the computer isn't getting data from the cable or that Finale isn't getting data from the computer. Any further ideas about what I could check? Thanks!
Thanks.
Thanks.
