Randomly sounding notes- where is the problem?
Hi I’m hearing unwanted randomly sounding notes that haven’t been played.
Here’s my set up:
Roland FP4 - 5pin midi- Scarlett 6i6
MacBook m2 8GB - satechi usb hub - 6i6
MacBook - satechi usb hub - korg nanocontrol
Running MainStage with an addictive keys vst. No other plug ins.
Notes are loud and sustained. Don’t stop until I hit a reset/panic button in MainStage which is very disruptive.
Where’s the most likely source of the problem?! Where should I start?
Any help very gratefully received!!! Thanks!!
Is this while you're playing manually, or while using a MIDI song file, or while using an auto-accompaniment, etc.?
Hmmmm interesting. Looks like I've got some more reading to do... I had assumed it was a hardware problem with a faulty socket/cable or usb hub.
(yes it's happening when playing live)
It could be hardware related, but examining the output that's going from the keyboard/controller to the MacBook using a MIDI monitor may help you track down where it's coming from, then you'll be in a better position to come up with a solution.
OK, I'm not going to spoon feed anyone about how MIDI feedback loops work. Just google it and RTFM for how to toggle LOCAL ON/OFF.
Local On/Off just controls whether the keyboard produces its own sounds when you play it, not whether it transmits MIDI.
If he were getting duplicate notes all the time-- the keyboard's sounds plus identical notes playing in some external sound module-- that would be a Local On/Off issue.
But he hasn't indicated that he's getting duplicate notes all the time, just random notes out of the blue which need to be terminated using reset/panic.
I think he should try turning Local Off and report back just to satisfy you, but I don't see how Local Control could either cause or prevent MIDI feedback; that would be more of a MIDI routing issue.
keyboard player
