RD-800 live sets change by external midi device
Hi there,
I wonder if anyone found a solution for changing live sets remotely? I need to do this, using the RD800 live in combination with a Motif XF and controlling the setups for each song from the Motif masters. I know the msb, lsb and pc codes from the sound list, but it seems as if the RD800 does not respond to it. Which midi channel do I have to use to transmit the midi data for this, and what else do I have to consider to make it work?
Thanks a lot and kind regards
Georg
