I need to post this because I cant edit a previous post on the problem.
I have a brand new Ketron SD1000 sound module.I own a Roland RD700SX stage piano.When I connect them up via MIDI cable the Sd1000 doesnt play all sounds in each bank.This is how it connects up:
I connect the module with a Midi cable from Midi In(module) to Piano Out 1(piano).
I connect dual RCA's from L-R on module to amplifier.
I can connect either dual RCA's (module )dual RCAs to amplifier or dual RCAs from module to 1/4 inch to amplifier.Even Dual RCAs module to duals 1/4 ich input on Tascam DP03 recorder/mixer.
I switch on piano,amplifier,module,
I bring up display screen: MSB LSB PC.
I set the banks as:0,1,10,11.
I set the PC to 1-128.I scroll through all 128 sounds per bank.
It does work.But,it doesnt play all tones/sounds.It seems to play way more piano sounds that there are on the module.It also plays only 2 of the 20 electric pianos.This tells me there's a fault.This is also a problem with every SD1000.
Here's where it gets interesting.I still have the Ketron SD2 sound module that I bought in January and this connects up exactly the same way and it plays perfectly.
I wanted more electric piano sounds so I bought the Ketron SD1000.
I was told that the fault with the SD1000 is a bug issue in the Midi Port.Now I'm not convinced thats the problem.I was also told I can alleviate the midi problem by connecting module,piano and computer or ipad via USB.I really want to connect it up via MIDI cable and start using it.
Can anyone relate to this,or can you see where the problem is?
Thanks.
Thanks.
