Dave, thanks for that. I didn't know about those adapters. Much appreciated information.
Follow up question, if I may... The Casio PX-S3000 give you the option to set your expression pedal to Type1 or Type2.
Does that pretty much take care of the compatible pedal issue?
Thanks again...
I just pulled down the manual. Here it is ->
manual link
page EN-9 explains it, though not well....
- Pedal resistance must be 10k ohms to 50k ohms. the FC7 is 50K ohms, so it qualifies.
- Type 2 supports Roland EV-5, Kurzweil CC-1 (my Kurzweil follows the Roland logic) and Fatar VP25 and VP26.
"Type 1" has the resistor on the tip (this is the resistor attached to the 'wiper' which performs the measurement) which is consistent with Yamaha pedals.
"Type 2" has the resistor on the ring (this is the resistor attached to the 'wiper' which performs the measurement) which is consistent with Roland pedals. Also this is consistent with the statement in the manual about "...Type 2 supports Roland EV-5, Kurzweil CC-1 and Fatar".
So the answer appears to be that Type 1 is the setting needed in order to support the Yamaha FC7.
Also, if you are handy with a soldering iron you can build your own adapter; purchase a 1/4" Male TRS plug and a 1/4" Female TRS plug. Solder the sleeve of one to the sleeve of the other, solder the tip of one to the ring of the other and finally solder the ring of one to the tip of the other (essentially reversing the tip and ring, aka the polarity). Throw them in a gig bag. This way in the event you are using any keyboard and you breakout your FC7; if it works on direct input then your gig, it is giving you erratic (i.e. not a linear response) simply throw the adapter on it between the keyboard and the pedal. I have several just for these purposes (also in case if a wire breaks on the adapter then you're screwed if you don't have a backup).
Here's the male end:
1/4" TRS male
here's the female end:
1/4" TRS female
Only thing missing is the soldering iron, the solder and the wiring to connect the plugs. here a wire example:
3 conductor wire
