I have a Roland Juno DS-88 and I’m trying to figure out a good way to record both audio and video.
I currently hook up the keyboard to a Focusrite Scarlett which I connect to my laptop (MacBook Pro 13’) and then use Quicktime or an online recorder called Hippo Video so I can capture both video and audio.
The problem is that the sound quality is *extremely* poor, as in choppy and static-y and even fades out completely at points. I don’t think it’s an issue with the Focusrite since while I’m recording I’m listening through my headphones which are plugged into the Focusrite and it sounds fine. I think it’s an issue with my laptop or the connection with the Focusrite to the laptop (I use USB). I’m not sure.
Any ideas on how to get a quality recording?
