registration memory in roland prelude version 2
hello.....
i bought a new roland prelude verion 2...and i m facing problem with registration memory,,can please anybody help me
Sweden
Hi neeraj,
what do you mean with problems with the registrations memory? You should describe the details otherwise nobody can help you.
With regards
hello....
i mean to say that i m unable to work on with registration memory part....what is the exact procedure to do the registration in the keyboard.....i want to store some selective voices in that
with regards..
Sweden
hi nerraj,
I read the manual and found on page 39 the following:
Page 39 of the manual:
Here’s how the settings of the current Performance can be saved in the Prelude as a new Performance.
1. Press [WRITE].
2. Use [] [] to select “Performance,” and then press
[ENTER].
Input a name for your user Performance
3. Use [] [] to move the cursor, and turn the VALUE
dial to change each character, and then press [ENTER].
Enter a Performance name of up to 16 characters.
The following characters are available.
space A~Z a~z 0~9 ! “ # $ % & ‘ ( ) * + , - . / : ; < = > ?
@ [ \ ] ^ _ ` { | }
Button Explanation
[0] Selects the type of character. Each time you press this, you will alternately select the first character of a character set: uppercase (A), lowercase (a), or numerals and symbols (0).
[1] Deletes the character at the cursor location.
[2] Inserts a space at the cursor location.
4. Turn the VALUE dial to select the desired destination, and then press [ENTER].
A confirmation window will appear.
5. Press [ENTER] to save the Performance.
If you press [EXIT], you’re returned to the previous screen without the Performance being saved.
Did you try it in this way?
With regards
Nils Petter Roald
