- Joined
- Apr 25, 2018
- Messages
- 158
- Reaction score
- 77
Recently moved house, and I know for sure that the removal of my Tyros was done with extreme care, as it was done by myself in our car.
So, on getting it all up and running again, I'm confused to find that my Registration folder is not reading from the Tyros internal hard drive.
Zilch, nothing..... When I press Registrations as normal I'm just getting a greyed out folder called P1 (page 1).
I removed the whole folder, and reinstalled it from my back up. Still nothing. Did the same again with my second back up. Still nothing.
All the files are. RGT, so Reg 01.rgt /Reg02. RGT and so on, and we're all fine prior to moving.
Totally baffled..... Can anyone suggest a reason, or even better a solution?
Thank you...
Thank you...
