Nothing wrong with those software choices but you might want to explore working with other DAW software and you simply MUST have some sort of MIDI controller if you plan on recording to a DAW. Working with Audio recordings can be nice but you have so much more control with an actual keyboard hooked up to the computer.
I'd recommend an Alesis V61 which is a pretty decent budget priced entry level controller for working with VSTis and Samplers.
https://www.amazon.com/Alesis-V61-Keyboard-Controller-Buttons/dp/B00IWWHIUI
$170 is a small investment for any serious musician and it will take you so much farther.
I'd also recommend a more professional DAW such as Reaper which is uncrippled and the demo never expires.
If you need help with Reaper just check Youtube for Reaper Tutorials and you will find step by step guidance on how to use every function.
Once you start inputting your notes directly into the computer you'll never want to go back to your old methods.
