Description of problem
My MIDI Keyboard used to work on my computer, but suddenly stopped working around a year ago. It's a Roland A-800Pro. When I plug it in to any USB port and turn it on, the display on the midi turns orange but nothing happens. Windows doesn't make a noise that a new device was attached, and BIOS says nothing is in the USB port. The device doesn't show up under device manager either. I'd really appreciate any help I could get.
What I've tried so far
- Turned off USB selective suspend
- Multiple USB ports tested
- Two cords tested (both work on my condenser mic)
- Tested on another PC in my house running the same OS (Windows 10) and it works perfectly
- Booted PC in safe mode and tested
