Roland A-90 EX (expanded sound card) has no harpsichord sound
What can I buy? Totally a novice to add on equipment. Own the A-90. Live in Mexico. Shipping is an issue.
Sweden
Hej, hej Steve,
the model A-90 EX indicates that it is an A-90 equipped with the VE-RD1 expansion card.
As far as I understood the manual you have to change this card against the new one.
Before you do this you should make a backup of your system.
How to change the card is illustrated in the owners manual of VS-GSPRO.
In my opinion I would check if this all is worth the money or if it isn't better to buy a more modern used synth or stagepiano?
