Roland E09 becoming offtune
Hello, I have a Roland e09 that I always play in church for around a 2 and half year, yesterday after connecting the sound when I was playing it the main voice was becoming off key but the bass still fine on the same key, can someone help that what's the problem and how can I fix it.
Normally I'd say it's the pitch wheel acting up but if the problem is not duplicating itself across a split I'd say the first step is to back up your settings and then perform a factory reset on the keyboard to eliminate a configuration problem.
If the problem persists after that it is most likely a hardware problem in need of attention.
Iwll
How can I solve that kind of a problem?
