Roland FA08 organ patches
Hi all. I'm having a problem with the organ patch on the keys I'm using in that it's way too loud compared to everything else. It's blasting out of the amp at deafening volume whereas strings and piano patches are fine. I'm resorting to just controlling the master volume but the sound guy is complaining that it's affecting his mixes. Is there anything I can do?
I'm not familiar with the FA08 but most workstations offer the ability to edit patches and change values like entry volume and save them either back to the same slot else as a performance or setup.
Check your manual and look at values like max velocity and entry volume and see if they can be twiddled with.
