- Joined
- Apr 26, 2019
- Messages
- 584
- Reaction score
- 158
Quick question : I recently bought a Roland FP-E50, which only has USB midi (no 5-pin) ; I also have a Korg Liano. Again, no 5-pin, only USB midi.
Both these boards have built-in speakers, with Audio and MIDI over USB.
I realize I cannot connect these two in the traditional way (MIDI OUT on the Liano to MIDI IN on the FP-E50) and I cannot simply connect them with a USB cable. So I will have to route the MIDI using an interface or a computer.
Simply put : how do I do this ? I have a Mac, a Scarlet 4i4 interface, and iLoud Micro monitors. What I would like to do is to be able to play the sounds from the Roland on the Liano (second tier). When connected to the computer, I would like to be able to use the iLoud speakers, my headphones (both of which are connected to my Scarlett 4i4), and if possible, be able to used the built-in speakers of both the Korg and the Roland when needed.
I have connected both the Roland and Korg keyboards to a USB hub that is connected to my computer. I see both keyboards in the MIDI control center of the Mac. But I'm a bit lost as to what to do next. I won't be using a DAW.
Don't know if this kind of setup is at all possible...
