I was totally sold, ready to put my money down on a new Roland E50: great keyboard action, superb SuperNatural piano sounds, over 1000 built in sounds, microphone input with effects, expandable number of sounds... I mean, the list just goes on an on. And then, someone alerted me to the E50's fatal flaw: it only has oneMIDI channel enabled, as opposed to 16 on most MIDI equipped boards. In addition, none of the rhythm sounds can be sent over MIDI. This all makes the E50 useless as a studio production machine, which was my intended use forthe instrument.
I was shocked, floored. The bottom line is that, at least with Roland, the phrase 'MIDI capable' and the presence of a USB MIDI jack, does not mean that the instrument is fully MIDI capable. Thank God I didn't make the purchase and then discover this 6 months down the road, when I finally got around to setting up my MIDI connections!
So, a word to those considering an E50: don't ever plan on doing anything with MIDI with the instrument. Roland has crippled it sufficiently as to make that impossible.
I wound up with a Yamaha DGX 670,and am satisfied that I got the best overall value for my money. The 670 lacks the triple sensor keyboard found in the E50, as well as a bunch of other things; but at least it is fully MIDI compliant. Points to Yamaha for that.
d
d
