Roland GW-7 - additional memory?
Hi all, I'm trying to find out if there is any way I can increase the User Performance memory, currently the machine only allows for a maximum of 32 tracks saved internally. Is there an external bit of kit I could interface (?midi?) to expand this facility? Any ideas gratefully received. It seems Roland doesn't support this keyboard so I can't ask them
Thanks, Steve
Easiest thing for you to do is MIDI it up to a computer or tablet and save your performances using a DAW software like Cakewalk.
If it only has DIN ports then you need to buy a USB MIDI Adapter like this one.
And Cakewalk by Bandlab is nowadays a free download here :
JerryK47
