Roland HP900 key removal
I have dead keys on my Roland piano which is almost 30 years old. I’ve studied a few clips on removing keys and repairing hammers.
I've managed to open the casing ok but whatever method is used to retain the keys is different to anything i have seen in clips.
Can anyone recommend a video clip showing removal of these keys please? Thanks, James
I found a brilliant clip on YouTube. Don’t know how I’ve missed it in the past. I searched on REPLACE KEY ON ROLAND HP900 PIANO. It does need a special tool but this clip shows you how to make one. Problem solved thanks.
Rajitha
