- Joined
- Feb 19, 2019
- Messages
- 2
- Reaction score
- 1
Can you change the sounds on the 8 phrase pads? Example, they come with a drum kit pre-loaded and you can use the pads to play drums live while also having a playable patch on the keyboard bed (not sequence or rhythm pattern) and I wanna change the drum kit or even just like the kick or the snare. Can you do that?
