Hello! Tomorrow, I'm picking up a used DS-61 and I have a couple of questions that I can't seem to find the answers to, so if any of you could help me out, it'd be greatly appreciated!
1. Layering: I want to layer 5-10 layers at a time, and I saw that you can control the volume in the performance settings. Is there a way to use the faders to control the volume(s) instead of the cursor buttons and jog wheel? If so, I assume there'd be a way to change which patch or set of patches the faders are controlling. In a live situation (where this will mainly be used), I don't want to have to go through each patch one by one using the buttons and wheel.
2. MIDI: If I want to use this as a master keyboard with my Yamaha MO8, would I be able to control the patches in a performance of the DS61 with that? (I apologize if that's something I would have to research about the Yamaha specifically. As you ay be able to tell from my question, I don't have any experience connecting 2 keyboards over MIDI).
I'm sorry if these questions weren't specific enough or anything, but as I said, I'd appreciate any help that you could give a beginner
