Hi everyone,
need help here...
I should buy a keyboard for my wife. She has a couple of needs:
1. 88 weighted keys (hammer action or anything similar to a real piano complete keyboard);
2. Possibility of - at least - 4 sections splitting (with indipendent transpose, dynamic range and sounds);
3. Vocoder with at least 6 indipendent voices (she wants to tune an input voice from an external dynamic mic into a 6-voices poliphony that follows the keys pressed);
4. Good sounds and controls;
5. Not over 20 Kg;
6. The budget is around 1000 euros
(I know... I should change wife model...
Now, CASIO PX-560 seems very impressive: Casio declares good sounds, efx and controls, and it seems that HexLayers function can split the keyboard into 6 sections, with indipendent transpose I suppose, but I'm not sure... If it's right, this PX560 has everything I'm searching for, BUT the Vocoder...
On the other hand, Roland JUNO-DS 88 should really have everything: if I'm right the 88-model should have weighted keys AND the Vocoder (but I don't know how many voices it allows, and if it has some compressor/EQ filter to compress the voice BEFORE voconding...) It has a simple 2-section quick splitter button, but it seems that you can anyway program a more complex splitting (more than 4 voices) with indipendent transpose (but, again, I'm not sure...)
So, now it's questions time:
1. Can you confirm that Casio PX560 can split up to 6-sections and that every section has indipendent transport?
2. Can you confirm that also JUNO-DS 88 can split at least into 4-sections and that every section has indipendent transport?
3. Is it true that PX560 HASN'T Vocoder?
4. Instead, about JUNO's Vocoder, how many indipendent voices can it handles?
5. Again about JUNO's Vocoder, is it possible to add some compressor/EQ filter to the input voice (mic)?
6. Can you confirm that JUNO-DS 88 model has weighted keys?
7. About all the other aspects (sounds and controls quality, efx, etc.) which keyboard would you recommend?
Thanks a lot for your help and advices!
need help here...
5. Not over 20 Kg;
