Thanks Gary. Are the connectors for each key or for a circuit board? Can you describe the deoxit ……First step would be to disconnect the connectors, clean with Deoxit, then reseat connectors and test.
That's where you start...
Thanks for taking the trouble to reply. I will try this next week. RegardsDisconnect the ribbon cables. Mark them first to get them the right way back.
Spray Contact Cleaner, Deoxit is a brand name, on the connectors.
PLUG THEM BACK IN THE RIGHT WAY.
If that doesn't fix it, take it to a service guy.
The key contacts are something else entirely.
Probably beyond you.
