Hey there!
I'm about to buy a keyboard tomorrow. I was opting for the XPS-30 (used). I later came upon Juno DS 61 (new) which is basically identical to the XPS-30.
Are there any differences in the sounds between the two? I did some research and the only difference I could find was that the XPS had 200-300 extra presets. I'm not concerned about that as you can add the presets to the Juno DS 61 as well. My concern is if the actual sound quality is different? Is XPS 30 better?
Thanks for taking the time!
