S70xs Performance issue
Renton
Ive created a performance with piano on part 1 with a foot controller assigned as volume. Part 2 is strings assigned fc 2 for volume. When I back of fc 2 completely there’s still a remnant of strings evident but if I increase the pedal a tiny bit it goes away- a sweet spot so to speak. What’s the fix so it’s 100% dry when the pedal is backed off completely?
Can you swap the two controls - maybe the slider on the potentiometer on that fc2 does not go to full ground unless you touch it forward. There is a degree of play between the potentiometer shaft and the link that drives it?
crafterofpixels
