- Joined
- Jan 17, 2014
- Messages
- 4
- Reaction score
- 5
Hello! I want to ask here a question that has not yet received an answer anywhere else , including the manufacturer of the instrument. I bought a MIDI keyboard Samson Graphite , all happy except for a "small " problem : function keys that can be assigned controller Change Programs are unable to configure the program number which should switch sound module or virtual synthesizer . For some reason, there is no possibility to edit the " Datа " parameter and all the buttons on the sound module switch to 127. Support Specialist gave me advice to update the firmware keyboard, but the program for PC probably does not work. Presets perfectly copied from the keyboard and back, but when I trying to update firmware, in the Graphit Edotor window appears this message several times : "Search the boot sector " and then " Failure . Check the connection and try again" USBcable ,was connected all the time . If anyone has ideas , what I have to do ( except for the obvious - attributed back to the store ), I 'll be happy.
