Seeking MIDI Converter for Passive Keyboard with Weighted Action
I have a passive keyboard (weighted action keyboard) where each key press generates an electrical signal that should translate into a softer or louder sound. It is connected to a broken motherboard through two flat ribbon connectors.
I want to salvage the keyboard and use it as a MIDI controller with a laptop or iPad, but I'm struggling to find a suitable signal converter. I'm seeking a converter that can detect the electrical signals generated by key presses and translate them into MIDI data. I'm aiming for the simplest solution, ideally ending with a USB plug. Do you have any recommendations for brands or products that meet these criteria? Thank you in advance for your help!
creekmusic
