Semi-weighted action for arthritis
Quick question for any who have arthritis in their hands who may have switched from a graded, hammer action board to a semi-weighted board...did the switch make much of a difference to your hands/arthritis? Is it noticeably less impactful on your joints?
Yes.
My semi weight causes me less issues than the Hammer action on the DP that I had.
Only way though is for you to visit a music store and play as many back to back as you can.
That said you may have issues finding a semi weighted keyboard with 88 keys as there are not to many around.
Ok, thanks Biggles; good to know. I plan on doing that...also I need to play around more with the touch settings on my board to see if a lighter touch for lengthy time period may even help a little.
I own a PC3K8 that needs repair and I replaced it with a Studiologic Numa Compact 2X. The Numa has 88 semi weighted keys and I suffer from arthritis during the cold and wet weather cycles. The Numa is definitely easier on the joints.
Ralph
