- Joined
- Nov 14, 2010
- Messages
- 7
- Reaction score
- 0
Hello everyone,
I am having a problem with my new Keystation 61es. The problem I have is that when I press the F5# on the keyboard then the C5 and C5# are not working at all and E5 is played as G4# and no release signal is sent (either for G4# or E5).
In what I mentioned above I have used the number of octaves marked on the keyboard. Below are the numbers that the computer sees. For example, if the key is marked E5 on the keyboard it is read as E7 by my PC.
Here is a copy of MIDI-OX' input.
Thanks a million!!!
What I would like to know is if this is a problem with the series or with my keyboard. Will this problem be fixed if I ask for a replacement?TIMESTAMP IN PORT STATUS DATA1 DATA2 CHAN NOTE EVENT
00080E24 1 -- 90 66 43 1 F# 7 Note On I keep this key down while pressing the rest.
00081434 1 -- 90 59 44 1 F 6 Note On
000814CA 1 -- 90 59 00 1 F 6 Note Off
000816A1 1 -- 90 5A 45 1 F# 6 Note On
00081749 1 -- 90 5A 00 1 F# 6 Note Off
000818D4 1 -- 90 5B 26 1 G 6 Note On
0008196A 1 -- 90 5B 00 1 G 6 Note Off
00081AEC 1 -- 90 5C 3A 1 G# 6 Note On
00081BA8 1 -- 90 5C 00 1 G# 6 Note Off
00081D2E 1 -- 90 5D 3B 1 A 6 Note On
00081DDF 1 -- 90 5D 00 1 A 6 Note Off
00081F7F 1 -- 90 5E 49 1 Bb 6 Note On
0008201C 1 -- 90 5E 00 1 Bb 6 Note Off
000821AA 1 -- 90 5F 42 1 B 6 Note On
00082246 1 -- 90 5F 00 1 B 6 Note Off As you can see there is no C7
0008286E 1 -- 90 61 00 1 C# 7 Note Off This appears only some times, but the 'on' event never appears.
000829E5 1 -- 90 62 4B 1 D 7 Note On
00082A97 1 -- 90 62 00 1 D 7 Note Off
00082E7A 1 -- 90 63 46 1 Eb 7 Note On
00082F27 1 -- 90 63 00 1 Eb 7 Note Off
00083440 1 -- 90 5C 40 1 G# 6 Note On And here I actually pressed and released E7, not G#6
000836E5 1 -- 90 61 3F 1 C# 7 Note On
00083DB5 1 -- 90 66 00 1 F# 7 Note Off
Thanks a million!!!
