Hi All,
Just came across this forum website today. I am not a keyboard player but am an electronic service technician for over 30 years now. A friend has asked me to try and sort out a fault on his Korg sp 250 keyboard. The symptoms are the following. When powered up the unit will activate the metronome or some other effects features without anything being touched. Sometimes the unit will appear to operate normally but when some base notes are pressed the metronome will activate. Some of the other effects led's will begin to flash. I disconnected the connection from the user button panel to the cpu board but the problem persists. The only checks I carried out so far was to check the 12, 9, 5 and 3.3V supplies. Am I looking at a new cpu board and if so can anyone suggest where I might purchase one.
Thanks in advance from the 'old timer'.
