- Joined
- Aug 8, 2015
- Messages
- 3
- Reaction score
- 0
Hello and thanks in advance for your help.
First post here so, hello to everyone!
I have an SP2x.
I try to set the time signature.
I follow the steps in the user manual, p.3-9 and 3.10, with no succes.
From the manual
Metronome Feature
To activate Metronome feature, press [Rhythm/Metronome] button and select “world” drum pattern category. And then, press [0], [+/‐], [Cancel] and [Enter] button in order. The SP2 supports 4 types of time signature including 2/4, 3/4, 4/4 and 6/8. After you make selection, the display will look like < Figure 3‐11 >. Use Knob D to control the tempo as you do with the drum patterns. "
I can change the time sig but it resets to 4/4 as soon as I select a program or a setup.
It's like there is a a kind of "confirm" step missing in the manual.
Anybody can help?
Thanks v. much!
I have an SP2x.
From the manual
Metronome Feature
Anybody can help?
Thanks v. much!
