I play a Yamaha S90ES and have keys that are sticking down after being struck. Anybody have any solutions? I have gigs coming up and need to fix this. Bad enough for piano sounds but impossible with sustain notes (organ, strings). I've tried opening it up. I couldn't figure out how to access the inner workings of the key action mechanism, but could see there metal rods that act as a counter weight to the downward pressure of the key, and when they drop are supposed to cause the key to pop back up again. I tried taping a wood screw on top of the metal rod for the key to add more weight. It changed the feel of the action, but for a while at least made it pop back up again. But, last night some keys were sticking again. Might be weather related, maybe worse with heat, humidity. Last night (outdoors) was cold and damp. WD40?
Why is it that malfunctions happen on gigs and not so much at other times? Do I need to replace my keyboard? Sending it to the shop would be expensive and would be unavailable for weeks. Like most of the keyboard sounds but dislike some other features of my keyboard.
Any suggestions would be greatly appreciated. Not sure how different my action mechanism is from other weighted key keyboards.
