- Joined
- Jul 25, 2015
- Messages
- 7
- Reaction score
- 1
Hi,
I have a Roland FP-5 controller and the sustain pedal doesn't function properly in LPX 10.2 (or 10.1) if using either a logic or GB legacy acoustic piano. If I press the sustain pedal, when I release it, the notes continue to sound.
This does not happen with an electric piano, nor with an EW acoustic piano plugin (QL pianos platinum).
It doesn't happen when using a Korg controller either.
Nor does it happen in Pro Tools.
Changing the switch on the sustain pedal from "switch" to continuous doesn't change anything.
The pedal gives readings other than CC 64 127 and CC 64 0 but as mentioned above, this doesn't prevent it working under all other conditions except in LPX and only then with one of the legacy acoustic pianos.
Any suggestions would be much appreciated.
cyrukoch
cyrukoch
