- Joined
- Jan 7, 2010
- Messages
- 3
- Reaction score
- 0
How do you use the Roland Fantom G series a a talk box. Like Roger Trottman.
I want to use the latter actuallyDo you want to know how to use a talkbox with your Fantom, or do you want to make a patch that sounds like you're using a talkbox with it? The former is easier - just plug it in. That latter is harder and would need a lot of experimentation.
