- Joined
- Sep 29, 2014
- Messages
- 205
- Reaction score
- 118
I was wondering if anybody had experience with a guitar to midi converter? And maybe what types might exist. I am not finding much on this right now or prices. Thank you and have a nice day.
Resistance to guitar synthesizers can be traced, in part, to the reluctance of players to add hex pickups or deal with the highly accurate picking and string damping required to make those systems function properly. Enter a product that could entice far more guitarists to join the electronic music party. The Boss SY-300 ($699 street) requires no hex pickup—only a standard 1/4” cable—and since there’s no audio-to-MIDI conversion involved, it’s latency free. Of course, this also means you can’t use the SY-300 to control other hardware or software synths.
In the SY-300, your guitar signal drives three separate oscillator sections that can be layered together. Within each section you can select wave shapes, alter them with filters, amp, and pitch controls, and modulate them with LFOs. You can apply onboard effects to individual sections, the whole mix, and your straight-guitar sound as well. Its step sequencer creates melodies and arpeggios from a single played note. Four footswitches let you bypass the synth sound, scroll through patches, and control three chosen parameters per patch. External footswitches or an expression pedal can be connected for further control. A Thru output sends dry guitar directly to your pedals or amp, and can also be used with the Return jack to create a loop in which to insert your own effects.
Thank you very much for the explaination. I think what i want or wanted doesnt exist. and Thanks everyone and have a great day.Guitar pickups produce audio signals.
MIDI devices produce and read digital note data.
The two are NOT easily compatible. There's no such thing as a simple convertor cable between the two.
Either you install a Roland GK3 MIDI Guitar Pickup on your current guitar to work with MIDI Modules like the GR-55 above, or you use an SY-300 which basically works by voodoo transforming audio notes and chords into MIDI note data which can then be routed to MIDI devices or use it's own internal synthesizer.
Other than those two retrofit options your only other option is to purchase a proper MIDI guitar.
There's very few on the market.
If you google "midi guitar" you'll be able to see what sort of bleeding edge hardware is out there these days.
Sweetwater pretty much carries all the commercially available guitar MIDI options out there, including the ones I've listed.
http://www.sweetwater.com/c593--MIDI_Guitars_Pickups/pn1
Another gadget worth mentioning is the Misa Digital Kitara but I think it's already been discontinued.
http://misa-digital.myshopify.com/products/kitara
But forget about simply buying a $50 cable and sending MIDI out of your Fender Strat. It just ain't gonna happen
