Timor is programming sounds for AKX10!
S
Scott Murrell
If you haven’t heard his sounds for Korg you’ve missed a treat and like me he loves the Medeli!
His company is Global Sounds and his prices are very fair considering the work and quality involved.
I’ve bought his sounds for my Korg PA4X and was blown away!
Also…
Upgrade in April that addresses some of my concerns? Possibly!
Writing …… Global Sounds for Korg Pa4X …… in Google to comes up with:-
As you did not seem to be able to find the link yourself I would caution you against trying to load the Sounds onto your keyboard, it is very easy to completely overwrite the existing sounds if you are unaware of the procedure.
Do create Backup and User Data files prior to any action involving loading anything into system memory.
I did Google it - but came up with a lot of results - none were of him.
Haven't purchased the keyboard yet...
Main concern is the sounds.
tc4m
