- Joined
- Oct 22, 2022
- Messages
- 2
- Reaction score
- 0
I have a new MODX7. When I got it I fired it up and everything seemed to be working fine except I noticed a problem with the main volume pot. The keyboard showed that it came with the rev. 2.5 firmware. I took the keyboard to the tech....and 2-1/2 months later....the main volume pot is now fixed under warranty. So yesterday I fired up the MODX. It started up with the live screen on the piano preset. I decided to change to the organ....and thats when I found out that now the touch screen is not responding to touch to select anything at all. Anywhere on the screen....presets, utility,.....nowhere can you select. It's frozen. You can switch screens by using buttons....but tapping anything on the screen does nothing. I also noticed that on the startup screens....it no longer mentions rev. 2.5 anywhere.....nor any version for that matter....
