tr-88
like every other keyboard it depends on what you want/need.
If you need a mid-range workstation with hammer action keyboard, then it's OK,
if you're aiming at playing the piano (and mostly piano sounds) then don't go Korg at all.
I find their piano sounds... well... weird :)
Write about what you need and expect from a keyboard and then we may be able to help you
Birmingham UK
Well - i took the plunge and got the tr88 - for £470 - which i dont think is a bad price for fully weighted keys.
not had a chance to play it much at the moment - but first impressions are good. the action on the board itself is really nice - better than my acoustic (which is a 30yr old bentley so it wouldnt be hard to beat!)
arps etc seem dance orientated - but not that bothered really - will be using it layer sounds on - and maybe controlled from another board anyway.
The stereo piano sound is ok - a weenie bit tinkly on the higher notes, but overall not a bad sample. im sure with a bit of tweaking i can get it to sound better.
So far so good! :)
m88
