- Joined
- Aug 30, 2012
- Messages
- 5
- Reaction score
- 0
I know this has something to do with my general lack of knowledge concerning midi, but I've tried to learn and am just not getting "it". Anyway, I bought my Roland over 20 years ago, used, and my Peavy Organ module is that old as well. Apparently, it is not a very common commodity. I've looked on ebay, and it is not there. Here's my problem:
these are two really old pieces I'm working with. First, I have a Roland RD-1000 digital piano with MIDI. Also, I have a Peavey Spectrum Organ Modulation Synthesizer (an Organ module). My Roland has set up for about 10 years with a broken sustain pedal which I just got fixed. I'm loving the piano, but I can't figure out how to set up the organ module. I've found the manual for the Roland online, but there is no manual for the module. I even called Peavey and the module never existed . The module worked with the piano 10 years ago. The piano hasn't skipped a beat and the module powered up and the display reads just like always. On both units there is MIDI in, out, and thru. I have the keyboard connected from MIDI in to the MIDI out on the module (I also have another MIDI cable if I need it...do I need it? I tried connecting both cables, but that didn't help). I have a speaker cord connected from the Mono jack on the module to the input on my Peavey amp. I went ahead and ran a cord from the keyboard to the amp, as well, but I really did that out of desperation. My Roland has two MIDI controls. One is "MIDI transmit channel' which goes from 1 to 16. The second is "MIDI recieve channel" which goes from Channel 1 Omni 1, 1, 2, 3, 4,....up to 16. I have both of those set to channel 1. The Peavy module is a bit more daunting. There are 8 buttons, a row of four that are above another row of four. I believe the top four are non-consequential as far as getting my module to work with my keyboard. They are XPOSE, FINE, R/CLICK, and VIBRATO. The bottom four buttons are DRIVE, SPKR, ROTARY, and REVERB. DRIVE and SPKR have a little line connecting them which reads "MODE". ROTARY and REVERB have a line connecting that reads "CHANNEL". When I simultaineously press the two buttons that made up "MODE", I get some half letters that might read "on1", and I can advance and also get "PoL" (which I assume means poly), "2CH", "3CH", and "4CH". When pressing the two buttons constituting "CHANNEL", I get "1"," 2", "3",,,up to "16". That's where I am. I realize the channels from the two units need to be the same, but so far, no go. I can take a picture of the module and keyboard if it would help. I hope it's something obvious that I'm overlooking. I'd like to get some of these cool organs sounds from my Peavey module to play on my Roland RD 1000. Thanks to anyone that read through all of this. You are a good person!
