Thanks!Here is a hint: If your keyboard shows note A4 as 440 Hz, then lower that note to 415.305Hz. That will make the E one half step lower than standard tune.
Welcome.
Do read through your keyboards manual and physically look at the controls and through the menu system.
I am not meaning to be patronising but often if there are not djustment buttons obvious there is a tuning function burried in the menu.
On one of my kerboards there are two sets of two tuning buttons each with + and - under them, one set does an octave shift whilst the other a 1/2 step.
So it should be an easy and easily reversible action to retune and test play.
Out of curiosity can you explain how and why you tune your guitar down 1/2 step?
I can understand The Stones or Jimmy Page etc tunes but not 1/2 step
If you want to quickly tune up or down a half step (semi-tone), most keyboards have a Transpose setting that lets you do that.
Basically, there are three levels of tuning:
- Up or down by a certain number of octaves.
- Up or down by a certain number of semi-tones ("coarse tuning" or transposing).
- Up or down by a certain number of Hertz ("fine tuning").
Generally there are separate buttons for shifting octaves versus transposing, but that can vary by keyboard; some have four buttons, two for octave shifts (up/down) and two for note shifts (up/down), while others may bury these settings in a function menu. Fine tuning is frequently a menu item.
Each level of tuning has limits, or how far up/down you can go. For instance, the fine tuning might be limited to a maximum of however many Hertz corresponds to 1 semi-tone, whereas the transpose might be limited to a maximum of plus/minus 12 semi-tones. So fine tuning the Hertz might work okay in this case, but generally speaking you'd be better off using transpose if you want to shift the pitch to a different note or key. Fine tuning is really more for tuning a given key ("Concert A") to a particular frequency for historical accuracy, or in countries where the preferred pitch of Concert A is something other than 440 Hz.
If you read his 3rd post it is because the band tunes down for vocal reasons.Why do you want to tune down?
